Looking for some help with better controlling points for angle dimension. Currently my script divides a beam into equal sections, orients each section onto a flat plane, and aligns their axis lines to be parallel to the World Y axis for consistent presentation. It then identifies key points like where the axis line intersects the section boundary, allowing for easy visualization, dimensioning, and documentation of each cross-section. It creates a plane parallel to the Z axis to be able to measure the degree of rotation of the beam. The problem I am running into is that I currently do not know how to control which line the script dictates to use for start/end points for the angle dimension plugin. Any suggestions would be greatly appreciated.
PLANE CONSTRUCTION_v5.gh (80.8 KB)
Arches.3dm (2.5 MB)
