Trying to access mesh in an Instance
I’m trying to access a geometry inside an instance, i can’t seem to find a way to get anything from instance.Geometry apart from : “AttributeError: ‘InstanceReferenceGeometry’ object has no attribute ‘Vertices’”
def CreateCutters(self):
    rc, obj_refs = Rhino.Input.RhinoGet.GetMultipleObjects(
        "Sélectionnez les pierres pour y ajouter les cutters", False, Rhino.DocObjects.ObjectType.InstanceReference)
    if rc != Rhino.Commands.Result.Success or not obj_refs:
        return
    cutter_ids = []
    for obj_ref in obj_refs:
        rhino_obj = obj_ref.Object()
        gem = rhino_obj.Geometry
        gem_vector, gem_size, gem_center = StoneFinder.get_gem_info(gem)
        print(gem_center)
        print(gem_vector)
        print(gem_size)
        plane_start = Rhino.Geometry.Plane(self.center, self.normal)
        plane_end = Rhino.Geometry.Plane(gem_center, gem_vector)
        orient_transform = Rhino.Geometry.Transform.PlaneToPlane(plane_start, plane_end)
        cutter_id = self.Cutters()
        sc.doc.Objects.Transform(cutter_id, orient_transform, True)
        scale_transform = Rhino.Geometry.Transform.Scale(gem_center, float(gem_size))
        sc.doc.Objects.Transform(cutter_id, scale_transform, True)
        cutter_ids.append(cutter_id)
    if cutter_ids:
        sc.doc.Groups.Add("Cutters Group", cutter_ids)
    sc.doc.Views.Redraw()
Hi @Yves_Gobinet,
You might want to include a sample .3dm file.
Thanks,
– Dale
There is the sample, thanks for the fast reply.
Sample.3dm (1.1 MB)
Hi @Yves_Gobinet,
Your code doesn’t include StoneFinder.get_gem_info. What does it to?
– Dale
Hi @dale,
Sorry for the late reply, get_gem_info check some vertices of the stone mesh and return size, normal vector and center point of the mesh.
import Rhino
import scriptcontext as sc
def get_gem_info(mesh):
    index5, index6 = 231,191
    index7, index8 = 59,19
    index9, index10 = 105, 145
    intermediate_point1 = (1 - 0.5) * indexToPoint(mesh, index5) + 0.5 * indexToPoint(mesh, index6)
    intermediate_point2 = (1 - 0.5) * indexToPoint(mesh, index7) + 0.5 * indexToPoint(mesh, index8)
    intermediate_point3 = (1 - 0.5) * indexToPoint(mesh, index9) + 0.5 * indexToPoint(mesh, index10)
    center_point = (1 - 0.5) * intermediate_point1 + 0.5 * intermediate_point2
    gem_size = intermediate_point1.DistanceTo(intermediate_point2)
    gem_vector = calculate_vector_from_points(intermediate_point3,center_point, intermediate_point1 )
    print(gem_vector)
    print(gem_size)
    print(center_point)
    return gem_vector, gem_size, center_point
def indexToPoint(mesh, index):
    vertex = mesh.Vertices[index]
    point = Rhino.Geometry.Point3d(vertex.X, vertex.Y, vertex.Z)
    return point
def calculate_vector_from_points(point1, point2, point3):
    vector1 = point2 - point1
    vector2 = point3 - point1
    normal = Rhino.Geometry.Vector3d.CrossProduct(vector1, vector2)
    if normal.IsValid and normal.Length > 0:
        normal.Unitize()
    return normal
To access a mesh inside a block instance you need to first ‘drill into’ the block instance.
With a block instance in rhino_object you’d do something like:
idef = rhino_object.InstanceDefinition
idef_objects = idef.GetObjects()
for ob in idef_objects:
    gem = ob.Geometry
Hi @nathanletwory
Unfortunately, this solution gives me the mesh of the block reference rather than the mesh of the selected block instance.
If you need the vertices in the space of the block instance you need to apply the InstanceXform.
I don’t know of a function that gives instance geometry transformed into the block instance space. @dale am I missing something
It works !
Thank you so much for your help @nathanletwory and @dale
