I’m using the new Rhino8 GetMeshes method elsewhere which works well for getting a brep’s render mesh but does not seem to work for block instances?
elif isinstance(geom, Rhino.Geometry.Brep):
rhino_obj = obj_ref.Object()
render_meshes = rhino_obj.GetMeshes(Rhino.Geometry.MeshType.Render)
all_meshes.extend(render_meshes or [])
Does anyone have a pointer for getting the render mesh from a block? I’ve been scouring these forums and web with no luck on this topic.
I continually get confused with how to access geometry of Instance Definitions from an instance reference…
Here’s a failed code excerpt attempting this:
elif isinstance(obj, Rhino.Geometry.InstanceReferenceGeometry):
try:
# Get the InstanceObjects associated with the InstanceReferenceGeometry
instance_definition_parent = obj.ParentIdefId # Get the parent GUID
# Ensure the instance definition exists
if instance_definition_parent:
# Get all objects associated with the instance definition
# objects = instance_definition_parent.GetObjects()
obj_ref = Rhino.DocObjects.ObjRef(instance_definition_parent)
print(f"obj_ref: {obj_ref}")
rhino_obj = obj_ref.Object() # Get the actual RhinoObject
print(f"rhino_obj: {rhino_obj}")
geom = rs.coercegeometry(instance_definition_parent)
# geom = obj_ref.Geometry()
print(f"Block Geom: {geom}")
# render_meshes = obj_ref.GetMeshes(Rhino.Geometry.MeshType.Render)
# objects = rhino_obj.GetObjects()
# print(f"objects: {objects}")
# geom = obj_ref.Geometry() # Get the geometry (Brep, Mesh, etc.)
# if geom:
# return geom
# else:
# Rhino.RhinoApp.WriteLine("No objects found in the block instance definition.")
# if objects:
# # Get the render meshes of the Instance Definition Objects
# render_meshes = objects.GetMeshes(Rhino.Geometry.MeshType.Render)
if render_meshes:
# If meshes are found, draw them
for mesh in render_meshes:
e.Display.DrawMeshShaded(mesh, material)
except Exception as ex:
Rhino.RhinoApp.WriteLine(f"Error getting render meshes for block instance: {ex}")
All of my print statements trying to get an object, geometry, mesh etc. all return none
I can explode the block recursively to get the brep and meshes but this is slow for detailed blocks. I Simply want to get the render mesh of the block for display conduit purposes…
Thank you in advance!
EDIT:
Made a little progress…
try:
obj_id = obj.ParentIdefId
all_meshes = []
"""Test"""
# Get the InstanceDefinition from the ParentIdefId
instance_definition = scriptcontext.doc.InstanceDefinitions.FindId(obj_id)
print(f"instance_def: {instance_definition}")
# Check if the instance definition was found
if instance_definition:
# Get all objects in the instance definition (block geometry)
objects = instance_definition.GetObjects()
print(f"idef objects: {objects}")
if objects:
for geom in objects:
# print(f"geometry: {geometry}")
if isinstance(geom, Rhino.Geometry.Mesh):
all_meshes.append(geom)
rhino_obj = geom.Object()
elif isinstance(geom, Rhino.Geometry.Rhino.Geometry.InstanceReferenceGeometry):
print(f"{geom} is a nested block instance reference")
# else:
# print("Could Not Draw Geometry In Objects")
print(f"all_meshes:{all_meshes}")
if all_meshes:
e.Display.DrawMeshShaded(all_meshes, material)
I now have the instance definition of the block but still not extracting its geometry with the GetObjects method…
