Trouble translating colors from Image to Hexagrid
Hi guys,
I ran into some problems trying to color my hex meshes with image sampler, as the image proportions seem to get distorted. I tried using various bounding boxes into the image sampler domain with no luck.My image is a square but I can edit it to be whatever I need to be really, I just thought making it a square would make things easier… which might no be the case so far.
The correct image being the one on the left, and the result on the right.
image here:
Def here:
image colors to hexgrid_v01.gh (769.5 KB)
use the correct domain
Hello
you still make newbie error, if you input bad coordinate in image sampler you can’t have a precise mapping
Here I use a 0 to 1 mapping.
You can check the position using that import image
image colors to hexgrid_v01_LD.gh (773.1 KB)
Thanks guys, image sample has always been rather cryptic to me, didn’t realize the domains ends were actual coordinates on the Rhino workspace!
Thanks @laurent_delrieu for the 0 to 1 mapping method, its nice to avoid editing the domain of the image sampler all the time!
