Trouble migrating Custom Grips to Rhino 6 C++
After migrating my custom grips plug-in into Rhino 6, I find the following problems:
  1. When enabling grips, the owner object keeps being on the scene, which makes it difficult to select grips as there’s continuously interference with it when picking. In Rhino 5 there was no issue with this as the owner object somehow “disappeared” as a pick option when enabling grips.
  2. When moving grips, the owner object is never transformed (I think m_bNewLocation flag is always set to false).
  1. From time to time there’s a crash when moving a grip.
I have these very same 3 problems in @dale 's example SampleCustomGrips. Still, cannot find the real change from 5 to 6 that causes the issue. Any idea?
Many thanks,
Pablo
Hi @pagarcia,
The sample you reference seems to work as expected here. I guess I’ll need more information in order to be helpful - sorry.
– Dale
Hi @dale,
This is odd… Could you please try my sample project? Maybe I’m making a mistake somewhere.
PlugIn1.zip (37.8 KB)
I’m using Version 6 SR8
(6.8.18240.20051, 8/28/2018)
Many thanks,
Pablo
Hi @dale, I updated the SDK (redownloaded and installed) and it works! So no issue now.
Just one thing, point 1 above
Is there a way to prevent this in R6? In R5 this didn’t happen.
Thanks,
Pablo
Hi @pagarcia,
I have no idea what you are describing. When you turn an object’s grip on, the object does remain visible.
I guess I’ll (still) need more info, screen shots, or something…
– Dale
Sure @dale : In Rhino 5, when you turn points on, if you make a window selection of the whole scene, you get this:
The selection includes the 8 grips. I.e. the owner object (the rectangle) is not included in the selection (though it remains visible).
In Rhino 6 this changes: the owner object remains selectable, so if I make a window selection it’ll include the 8 grips + the owner object.
This is a bit messy sometimes when you precisely want to select grips and not the owner object. Is there a way to prevent the owner object from being selectable once the grips are on?
Pablo
Actually every object with grips in Rhino has this issue, see:
Rhino 5 (sphere, 26 surface points added to selection):
Rhino 6 (sphere, 26 surface points + 1 surface added to selection):
You can see in the last picture that this makes the selection process a bit painful, as the mouse has to distinguish between the owner object and the grip the user wants.
Pablo
Hi @pagarcia,
Tools > Options > Mouse > Allow selecting objects with points on
– Dale
Awesome! Many thanks :+1:
Pablo
