Hi Charles - as is the object has large edge tolerances (_What command) - how was the existing trim on the surface created? If you untrim this, your new trim works as expected (here).
Hi Charles - the surface is OK, but there’s a trim in it as the file opens my question was about this trim - I could not reproduce the high edge tolerance here, starting from an untrimmed version of the surface and trimming again, so I was curious to know what the trimming object was for that initial trim- (seems to be the source of the out-of-tolerance…)
This trim appears to have cause the out of tolerance edges, I’m just wondering if the trimming objects for that trim are available - I completely understand if they are not, but if they are, I’d like to have them so that I could reproduce the whole mess from scratch, which might help troubleshooting.
