Trim/Split command causes topography to burst!
Hello everyone,
First time poster, but I’ve used the Rhino forums a ton, so thanks in advance.
I’m trying to trim down a 3D model that will be sent to a CNC router. The problem occurs when the topography surface that needs trimming basically spills in a very unusual way when I use Trim or Split along a polyline that I Projected onto the surface.
Boolean commands all fail and nothing else I can think of works. Very strange!
Hi Walid - please post a Rhino file with the surface and curves - thanks.
Topography file.3dm (2.1 MB)
Hi Pascal, thanks for the response. The file is above.
Hi Walid - to trim the longer surface to the curve that is there, UntrimAll the surface and then trim again with that curve - is that what you need?
Can’t believe it was so simple.
Thank you so much for your help!
