When I trim the solid cylinders with the surface, the cylinders become surfaces. Am I using the wrong parameters?
Trim_Test.3dm (3.0 MB)
You’ve described what Trim is supposed to do.
What do you want to happen instead?
If you want to be left with solids, use _BooleanSplit instead, then delete the leftovers.
HTH
Jeremy
Yes, I want the cylinders to remain closed polysurfaces.
