here’s a funky use of Anemone that might work for you.
The top version will go True for as long as it takes to count up to the input value. The lower, the faster, but it should be enough to trigger the K2 reset. The bottom will allow you to set a custom delay - so if the user updates the panel to a different number, there will be a short delay before the reset is complete. (This could all be hidden in the cluster, but Anemone will need to be installed).
timed reset.gh (11.5 KB)
