How to create a timed "True" Boolean Toggle for an Anemone Loop?
Hey guys,
I’m trying to figure out how to make the “Boolean Toggle” trigger switch set to “True” for as long as it takes to complete a loop using the anemone plugin in grasshopper and then default back to “False” afterwards.
Anyone have an idea of how to do this?
have you tried a button?
that’s what I used last. Just one press to initiate and it will run the defined repeats.
I tried using Button but it won’t complete the loop properly unless I hold the button down for the defined amount of loops. I think its because I’m using the “Button” output for the “D1” input. Basically I need it to pump out “True” “True” “True” etc. for every loop item and then end with a “False”.
@pascal Do you have any ideas?
