Treehelpers with weird runtime error
When doing the quite normal
output = ghpythonlib.treehelpers.list_to_tree( nestedList )
I get the weird runtime error:
Runtime error (MissingMemberException): ‘type’ object has no attribute ‘__index__’
Traceback:
line 32, in list_to_tree, […]
I’m not really sure why this comes up. Maybe @DavidRutten knows something?
Or somebody else ever had this error?
Using output = nestedList does “work” (you’ll get “IronPython.Runtime.List” of course).
output = nestedList[0] also works fine, you get what you’d expect.
without seeing the context…(no file), I’l guess and suggest this…:
output = ghpythonlib.treehelpers.list_to_tree(nestedList, True)
Thanks for your answer, Chris!
Sadly it doesn’t seem to help, tho.
There are too many LoC, but stripped down it’s basically like this:
class MyAgent():
    # init ....
    def make_some_geom(self):
          # make some geometry here
          nestedList[self.ID].append(someGeom)
if "agentsList" not in globals():
    agentsList = []
    nestedList = [[] for i in range(nAgents)] # make empty (sub-)lists so I can append later
#... init the agents here with ID
if RUN: # run is a bool toggle
    for agent in agentsList:
            # of course there is actually more here and not this function call directly
            agent.make_some_geom()
            ghenv.Component.ExpireSolution(True)  # instead of the timer component
# output
output = nestedList #....
@piac might be able to offer some further insight. I would guess it’s your nested list structure…
maybe this sample helps? (dummy example to show a basic nested list structure).
import ghpythonlib.treehelpers as th
uPts = []
# reparameterize input surface
S.SetDomain(0, Rhino.Geometry.Interval(0,1))
S.SetDomain(1, Rhino.Geometry.Interval(0,1))
# create columns of points on surface
# using a nested list will allow conversion to datatree
for i in range(0, U):
    newColumn = []
    for j in range(0, V):
        newColumn.append(S.PointAt(i * (1 / (U - 1)), j * (1 / (V - 1))))
    uPts.append(newColumn)
a = th.list_to_tree(uPts, True)
List2TreeSample.gh (6.5 KB)
how are you appending the empty lists?
this little snippet seems to work okay…
nAgents = 5
agentsList = []
nestedList = [[i] for i in range(nAgents)]
a = th.list_to_tree(nestedList)
I’m not sure why, but when I started Rhino today, my inital code (with treehelper) suddenly worked – no runtime errors so far.
¯\_(ツ)_/¯
https://www.timeanddate.com/moon/phases/
Excellent! I’ll flag this as the correct answer, I guess… :joy:
