Tree with a single branch
I’m processing a simple tree with branches like
{0}[list]
{1}[list]
etc.
I split it into two smaller trees using Split Tree, and sometimes (but not always) one of the sub-trees has only one branch. Grasshopper strips the tree structure from that sub-tree, and now my code is expecting a tree like
{11}[list]
but it receives only a list. The branch number, which is needed later when the tree will be merged back together, has been stripped.
Then data manipulation components don’t work the same on a list that is not a tree branch – to take the simplest example, Graft doesn’t behave consistently – and now everything breaks.
Is there a way to maintain a tree with a list or item in a single branch?
I can’t avoid needing to handle trees with any number of branches, and it’s a lot of work if I have to write a giant special case for the number 1.
Thanks!
I don’t understand because Split Tree is supposed to keep it’s data tree structure by replacing unselected data to “Null”.
What you’re talking about is Split List?
