Hi all,
I am having issues with transparent material for a CustomBrepObject, hope anyone could point me a direction. So here is a screenshot for illustration:
The original geometries (looks all fine with transparent objects).
Copied from above original geometries (gumball + drag + Alt). The top brep is seeing through all objects below as if there’s nothing behind.
Copied from above original geometries, and moved. The top brep is not showing correctly with the color of below objects.
Here is what I did for OnDraw in my CustomBrepObject:
protected override void OnDraw(DrawEventArgs e)
if (e.Display.DrawingSurfaces)
var material = new DisplayMaterial(Color.FromArgb(120, 75, 190), 0.2);
var mesh = RH.Mesh.CreateFromBrep(this.BrepGeometry, RH.MeshingParameters.Default);
e.Display.DrawMeshShaded(mesh, material);
else
base.OnDraw(e);
(note: code above is simplified for illustrating the problem)
I tried to set the material IsTwoSided to true, or set mesh.VertexColors with the color with alpha value, but they doesn’t improve anything.
material.IsTwoSided = true;
material.BackDiffuse = material.Diffuse;
material.BackTransparency = material.Transparency;
There are a several posts mentioned about EnableDepthTesting and EnableDepthWriting, etc, I couldn’t get them work.
I also tried to create custom DisplayConduit, it only works fine if I reorder the objects based on their distance from the camera. But this is very intensive, and Rhino’s view gets very slow when I have about 200 breps.
Hope this provides you enough information to understand this issue.
Thanks so much in advance.
