Hey, I am currently creating drawings for my project and want to make it clear that the windows in the model are see through within the drawings. through dashed lines or something. But idk what setting to change under “edit drawings” or whether or not to texture it? Currently nothing is textured, only that the layer of the glass has opacity applied to it within the layer colour.
simplest thing to do, just select the surfaces that make up the windows, and hide them.
in the drawing you will see thru the opening.
you can also set the object display properties to be rendered, which will show it’s transparent material, but that is more complicated than this needs to be.
