I would like to ask 2 things: Is it possible to make drawings as this two example images, where in one I have a monocromatic semi-transparent interior and in the other image it has a transparent part of the interior which highlights the other part.
how did you create this hatch? Is there a way to select the objects that I want and change the transparency of that item? If not it would be cool to have a feature like that on a detail in layout.
Isn’t that the same using Grayscale layer colors? You can also create a display mode that has no color and then set the detail to that display mode. Monochrome display mode is a good place to start I’d say.
