Trackpad gestures stop working after Macbook is put to sleep
Trackpad gestures stop working after Macbook is put to sleep. Each time i need to quit rhino and reopen. I’ve tested trying to repeat it when i close the Macbook or put it to sleep it doesn’t repeat the behaviour, so it is occasional, but has happened many times, especially when using the laptop intermittently and is annoying enough to let you know.
SYSTEM INFO
Rhino 7 SR22 2022-9-12 (Rhino 7, 7.22.22255.05002, Git hash:master @ 196b1bc7dd093321e28dcc7a2bb8709a9bebe12d)
License type: Educational Lab License, build 2022-09-12
License details: Cloud Zoo
Apple macOS Version 12.2 (Build 21D49) (Physical RAM: 32Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,2
Language: en-NO (MacOS default)
Apple M1 Max (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 21845 MB
Graphics: Apple M1 Max
Displays: Unknown (255dpi 2x)
Graphics processors
Apple M1 Max
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.22.22255.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.22.22255.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.22.22255.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.22.22255.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.22.22255.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.22.22255.5002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.22.22255.1002
I caught it in the wild. Had my mac close for a few minutes and it happened again. Quitting Rhino and restarting the program was the only way to fix it.
This one is a bit of a “white-whale” for us:
RH-70694 Trackpad on Mac stopped working correctly after laptop sleeps
we’ve all experienced it, but have had a horrible time reproducing and debugging it.
If you need any help its still happening with an up to date Rhino 7 (not upgraded to 8 yet). It tends to happen after the mac has gone to sleep and woken up again. What is most frustrating is having to close the program, that means, if I have multiple windows open, I need to close them all and open them all again. Its such a shame because the track pad is sooooo well integrated into Rhino for Mac its a dream otherwise.
Just so you know, this still is happening on a regular basis.
