Greetings,
I have uninstalled both pieces of software in Subject but the toolbars still remain in Rhino 7 after restarting Windows 10.
How can I get rid of them?
Thank you in advance for any sign.
Greetings,
You should be able to find them in Options > Toolbars
I would espect them to be in the Files list.
Select > right-click > close
Any luck?
Greetings and thank you for the suggestion,
The problem is I would like to completely delete them, removed from Rhino.
I am about updating Vray and Lands Design and I have noticed after uninstallation the toolbar are are still there.
And once installl Vray 6 for instance the new Vray toolbar is created.
Thus I have them both whilst one useless.
Briefly - no luck at all.
Hi Artur -
When you go to Rhino Options -> Toolbars
, all toolbar files will be shown in the list at the top right. When you then click on the file for the plug-in, you will see the path where this file is located. Exit Rhino and delete the file in Windows Explorer.
More luck?
There can be no more luck.
I see and I do thank you very much with my best regards.
