I write a c# component to test timer component:
and connect a timer to it,interval is 1 second.
so the number add 1 every one second.
then i change interval to “10ms”,so the number will add 100 every one second
but in fact it not,almost need 3 seconds to add every 100.
it seems a bug in timer.
who can explain that,thank you!
Seems like compiling and executing your c# script takes around 20 milliseconds? Or a delay due to the rendering and update of the display?
I’d assume the timer tries to trigger a new solution every 10 ms. But I guess if the solver is busy, that’ll get delayed.
thank you dsonntag,tomorrow i go to check.
Maybe this can help
private void RunScript(bool run, bool reset, int ms, ref object A)
if(run)
c++;
GrasshopperDocument.ScheduleSolution
(ms, doc => {Component.ExpireSolution(false);});
if(reset) c = 0;
A = c;
// <Custom additional code>
int c = 0;
https://developer.rhino3d.com/api/grasshopper/html/M_Grasshopper_Kernel_GH_Document_ScheduleSolution_1.htm
Timer2.0_Forum.gh (4.5 KB)
This does exactly the same thing as the other example with the timer? Also here it takes 3 seconds to count to 100. And my guess is if I start some heavy calculations in the background that will even be more. Which is also what is to be expected, the solution including the redraw will create a delay.
thank you ,i tried your code above,and when set ms =1000,it add 10 every second,i donnot know why can you explain it ,thank you~
