Tiling a curved surface with a white-to-blue gradient
Hello
finding center lines is not an easy task as center is not well defined. It seems best to draw the center lines using Rhinoceros.
I tried an approach that could help you a bit. The idea is to put weights on high curvature parts. Then smooth the weight using some smoothing or “Heat”
here I use my tools from Nautilus
Then I transform the weights on vertices to a Vector field.
Mesh iso splitting could also help
mesh middle.gh (177.6 KB)
