The unspittable surface
Well, it’s about three moons, and I’ve stuck with your advice for the most part. My line work improved markedly when I realized I should turn off the smart-tracking. I’m getting satisfactory results with several methods now and the sweep sometimes is easier to execute than others. Blending surfaces for complex transitions gives nice results but I limit that to where it’s needed.
This is tangential, but as you can see from the images, I’ve a tiny naked edge in the model, and while I’ve extracted and remaded and joined surfaces, I cannot eliminate that little fault. Is there some efficent method to deal with such a tiny problem?
ZebraDot.3dm.zip (531.6 KB)
Use ExtractBadSrf command, you will see you have some bad surfaces , you just need to reconstruct this.
Cleaned version :
ZebraDot.3dm (2.0 MB)
Thanks! I learned another important command.
I also like the createsolid you shared as well.
