The Selection Filter
Hey @Pascal,
I’m directing this at you because you seem to be the most involved with the nitty, gritty, nuts & bolts of Rhino:
Question/ suggestion about the selection filter. Great resource as it is, you know how you can right click on one option and it turns the others off? And then you right click on the same option and it turns any other filters that were turned on before, back on? Well this latter thing does not seem to happen after a few steps, and you have to go in and one by one turn the others on. Could we have an option built right in to the toolbar to Enable All?
Hi Cosmas - it is does not leap out at you but this is in fact there- right-click twice on ‘Disable’ to restore all. You could also make an alias/shortcut/button for this macro:
'_-SelectionFilter ShowDialog=Yes  Curves=Yes  Surfaces=Yes  Polysurfaces=Yes  Meshes=Yes  Annotations=Yes  Lights=Yes  Blocks=Yes  Points=Yes  ControlPoints=Yes  PointClouds=Yes  Hatches=Yes  Others=Yes  DisableFilter=No  Enter
This is nestable…
Awesome. Thank you.
