The question of Rhino.Inside
I have bulid Rhino in Winforms.
Can Rhino.Inside use select function?
Thsnks.
Hello @Chen_Chen
Welcome to the community!
I’m understanding that you have created a Winforms application that is loading Rhino and created a preview window? Are you looking for a way to click in preview window and select a geometry?
Yes.Exactlly.Is there anyway to do this?
Thanks
@Chen_Chen We do have an Sample app for Rhino.Inside.Revit in Winforms here
SampleWinFormsApp
This is an example of a method that handles selection
Thank you so much .It works
Hi Ehsan, I could not select the subobject by the code. Will you please check the example, Thanks.
