@menno
I have making test on this piece of code, is mess ok’:
namespace StCam.Conduits
class GcodeConduit : Rhino.Display.DisplayConduit
public GcodeConduit()
protected override void DrawForeground(Rhino.Display.DrawEventArgs e)
var rhinoscript_object = RhinoApp.GetPlugInObject("RhinoScript");
var rs = (IRhinoScript)rhinoscript_object;
//get todos os objectos
var objs = rs.ObjectsByType(4, false);
if (objs.ToString() == "")
return;
foreach (var item in objs)
if (rs.IsObjectHidden(item))
continue;
var tool = rs.GetUserText(item, "tool");
if (tool.ToString() != "")
SetLineColor(tool.ToString(), item, e);
var dir = rs.GetUserText(item, "angulo");
if (dir.ToString() != "")
double sentido = 0;
if (double.Parse(dir) == 0) { continue; }
else if (double.Parse(dir) < 0) { sentido = -90; }
else if (double.Parse(dir) > 0) { sentido = 90; }
var pontos = rs.DivideCurve(item, 10);
int count = -1;
foreach (var ponto in pontos)
count = count + 1;
if (count == 0)
continue;
if (count == pontos.Length - 1)
continue;
var param = rs.CurveClosestPoint(item, ponto);
dynamic domainStart;
domainStart = param;
var domainEnd = domainStart + 0.001;
var ponto1 = rs.EvaluateCurve(item, domainStart);
var ponto2 = rs.EvaluateCurve(item, domainEnd);
Point3d st = new Point3d(ponto1[0], ponto1[1], ponto1[2]);
Point3d se = new Point3d(ponto2[0], ponto2[1], ponto2[2]);
double degree = sentido * 0.0174532925;
Vector3d vec = new Vector3d(se - st);
vec.Rotate(degree, new Vector3d(0, 0, 1));
Line linha = new Line(st, vec, 3);
e.Display.DrawArrow(linha, System.Drawing.Color.Maroon ,15,15);
//cria texto visual do angulo inserido
var center1 = rs.CurveMidPoint(item);
Point3d center = new Point3d(center1[0], center1[1], center1[2]+5);
//e.Display.Draw2dText(dir, System.Drawing.Color.Blue, center, false, 30);
TextDot dot = new TextDot(dir ,center);
dot.FontHeight = 25;
e.Display.DrawDot(dot, System.Drawing.Color.White, System.Drawing.Color.Black,
System.Drawing.Color.Black);
private void SetLineColor(string tool,object linha, Rhino.Display.DrawEventArgs e)
var doc = Rhino.RhinoDoc.ActiveDoc;
var st = rs.CurveStartPoint(linha);
var mi = rs.CurveMidPoint(linha);
var en = rs.CurveEndPoint(linha);
Point3d start = new Point3d(st[0], st[1], st[2]);
Point3d mid = new Point3d(mi[0], mi[1], mi[2]);
Point3d end = new Point3d(en[0], en[1], en[2]);
//define a color
System.Drawing.Color cor = new System.Drawing.Color();
if (tool == "0") { cor = System.Drawing.Color.LightGray; }
else if (tool == "1") { cor = System.Drawing.Color.Black; }
else if (tool == "2") { cor = System.Drawing.Color.LightCyan; }
else if (tool == "3") { cor = System.Drawing.Color.Green; }
else if (tool == "4") { cor = System.Drawing.Color.Red; }
else if (tool == "5") { cor = System.Drawing.Color.Blue; }
else if (tool == "6") { cor = System.Drawing.Color.Yellow; }
if (rs.IsCurveLinear(linha))
Line line = new Line(start, end);
e.Display.DrawLine(line, cor,3);
else if (rs.IsArc(linha))
Arc curva = new Arc(start,mid,end);
e.Display.DrawArc(curva, cor, 3);
else if (rs.IsCircle(linha))
var ce = rs.CircleCenterPoint(linha);
Point3d center = new Point3d(ce[0], ce[1], ce[2]);
Circle ciculo = new Circle(center,rs.CircleRadius(linha));
e.Display.DrawCircle(ciculo, cor, 3);
else
//var divisor = rs.DivideCurve(linha, 50);
var polyline = rs.ConvertCurveToPolyline(linha, false);
var divisor = rs.CurvePoints(polyline);
rs.DeleteObject(polyline);
List<Point3d> listaPontos = new List<Point3d>();
IEnumerable<Point3d> lista;
foreach (var div in divisor)
Point3d ponto = new Point3d(div[0], div[1], div[2]);
listaPontos.Add(ponto);
lista = listaPontos;
e.Display.DrawPolyline(lista,cor,3);
partial class GcodeDirection
static GcodeConduit m_draw_conduit;
public static Result ConduitGcode(RhinoDoc doc, bool state)
if (state == false)
m_draw_conduit.Enabled = false;
//m_draw_conduit = null;
else
m_draw_conduit = new GcodeConduit();
// toggle conduit on/off
m_draw_conduit.Enabled = true;
doc.Views.Redraw();
return Result.Success;
