I would like to display a temporary text dot while I’m looping through some code… I found
Rhino.Display.DisplayPipeline.DrawDot Method (Point3d, String)
but I don’t know how to implement it… This doesn’t need to be dynamic, just display at a certain point and then disappear again… Right now I’m just adding the text dot to the document and deleting it again, but I would like to know how to do this only in the display…
Edit: as an auxiliary question, to add a text dot to the document, we have
sc.doc.Objects.AddTextDot(td,attrs)
and I can attribute a color other than the active layer color by using
attrs=Rhino.DocObjects.ObjectAttributes()
attrs.ObjectColor=System.Drawing.Color.Somecolor
But how do I attribute a text color to the dot? It seems it should be possible…
DisplayPipeline.DrawDot Method (Point3d, String, Color, Color)
(the second color being the text color)
Thanks, --Mitch
