Hi all,
I’ve seen some similar posts but haven’t found a good solution for me. I am running into an issue where I have a set of Text values that need to be converted to Numbers but fails.
I have two sets of similar sizes with different values. The top (sDA) values work while the bottom (ASE) set does not successfully convert. Any idea what the issue is? I’ve checked for nulls and it seems to generate the issue although I cannot find the index or workaround. Strange to me as the starting sets seem to be very similar.
textissue.gh (121.7 KB)
Thank you,
Reinhardt
