I want to show some text and want it to keep the same size even if the user zooms in or out. Is that possible?
Hi Dale,
I created this for tests using the Text command but my goal is to draw this myself using a conduit. I want to draw those gumballs from the other case together with a label showing the name of it.
There are a couple of DisplayPipeline.Draw2dText samples in the C# samples on GitHub.
You might clone the repo, open the solution, and search for Draw2dText.
ā Dale
Exactly what I needed. Thank you very much!
