Hi guys,
I know you can assign text height on Text Entity component via Text Settings component but why does the text entity do not adopt the adjusted text height when you adjust the model scale in annotation style? only the baked text adopts the adjusted height.
Even if you multiply the text height to the model scale, the baked text entity just becomes bigger.
What I want to achieve is consistent height between the text entity and the baked text entity.
Similar to the elefront Define Text Object Component below
