I started using Rhino 8 instead of other CAD SW apart from 3D modeling. When I started dimensioning the openings (windows), I got lost.
I need a trivial thing (fe. here Add text below dimension line - #2 by pascal) and works imho in every CAD SW, and that:
fe. for windows add the height of the opening and the height of the parapet/sill under the dimension line (so it is optional, only for some dimensions, it is standard in middle Europe in building plans)
if I press enter, it doesn’t work for me (it used to work long ago as I found it here >
if I set “Alternate units below” in Annotation styles I cannot get rid of this “Alternate units” in brackets
if I set “Dimension text” from “Above line” to “In line” for whole Annotation style it moves all dimensions, not working for me and the line is interrupted in the middle
if I use “Above line” it doesn’t work as I expect (this could be imho the most intuitive solution if I edit it with Enter/new line – as it worked before)
One hack is to set annotation style with Dimension text set to “Above” and than locally set it to “In line” fe. for windows, but the line is interrupted and takes a fews seconds to do it.
Is there any way to do it as it worked before, please? It is quite cruicial for me for building plans and I dont wanna install again any other CAD.
Thank you in advance!
