Text as parameter in VisualArq - Grid Bubble
I am trying to do a parametric grid bubble for VisualArq using a grasshopper definition, mostly based on this tutorial: Annotations - VisualARQ
I have succesfully inserted parameters for length, font size, bubble position, etc:
Still, if i input a text on grasshopper like this:
The text is read as a static geometry. Is it possible to create text as a parameter that I can change depending on the object, so I can name every grid separately? Alternatively, is there a way I can create grid lines just like levels are created?
Best
Luiza
Hi @Luiza_Longo
there was no file, so I took the Annotation tutorial file as a base.
You can add as an input a Text component, and make it editable by object.
Hi @Luiza_Longo,
First of all, we have implemented parametric grids in VisualARQ 3 and, if you have a license, we will send you a Beta version in the following weeks (just in case you prefer to wait for that version instead of developing this Grasshopper Style).
In any case, here you have an example of what @Toni_Osterlund (thank you!) explained:
Text.gh (5.8 KB)
Text.3dm (2.6 MB)
