Sweep1 with Parallel Sections
How do I create a swept surface with one rail and an planar section curves in parallel planes which has all V isocurves exactly in planes parallel to the section curves?
Here is a simple example of curves and rails: SweepQuestion1.3dm (32.5 KB) Please note that the rail and section curves may be more complex than this simple example.
Sweep1 with the "Roadlike Top"option should create the desired surface for the example rail and curves based on the description in Rhino Help.
Roadlike Front
The shape curve maintains its angle to the Front construction plane throughout the sweep.
The shape curves in the attached example are all in planes normal to the Front construction plane. Unfortunately the shape curve using Sweep1 with the Roadlike Front option does not maintain its angle to the Front construction plane throughout the sweep. See the attached file for what it does.
SweepQuestion2.3dm (42.7 KB)
Hi David - Roadlike … it does not mean the sections stay parallel to the selected plane, even though that is also a legitimate way to handle the sections - it is a little hard to describe other than ‘roadlke’ but here’s an image of some rectangles arrayed ‘roadlike;’ (red) and ‘freeform’ (cyan) on a wiggly curve- the original is on the right:
I think you can get what you want by -
  • ExtrudeCrv the path level with the Top plane.
  • Sweep1 along the edge of the surface using the ‘Align with surface’ style in sweep 1:
I probably should not have mentioned the mysterious “Roadlike”, too much of a distraction. I won’t mention it again in this thread.
[quote=“pascal, post:3, topic:33855”]
[/quote]That gives me what I want. Not at all obvious. Thanks. Much appreciated.
An option for the section/shape curve direction in Sweep1 and also in Sweep2 to use simple blending/interpolation of the section/shape based on the input section/shape curve direction only and not the shape of the rail(s) would be very useful. It is not at all obvious why in a simple sweep the shape/section curve wiggles around between the input shape/section curves.
Just to add to the discussion, since this was the first result that popped up when I searched:
It seems that in Rhino 6 you can now use ExtrudeCrvAlongCrv to get a parallel sweep.
Weird that it’s not a part of the Sweep command, and I don’t know the icon for it, but there you go.
ExtrudeCrvAlongCrv is not new in Rhino 6. It has been available in previous versions of Rhino. However it only works with a single section curve, not multiple section curves.
Very much agree; “Sweep 1 Rail” should behave like Alias’ “Monorail”, meaning with a natural and a parallel sweeping option, instead of hiding the parallel option in another command ; )
Please note that ExtrudeAlongCrv has existed since Rhino 1.0
Also note that there is an important procedural difference between Extrude and Sweep - Sweeps can accept multiple profile curves, whereas an extrusion is based on a single profile.
So yes, you could call ExtrudeAlongCrv a Sweep-type operation, but it would be a limited subset of that.
This is the major difference.
Another difference between ExtrudeAlongCrv and Sweep1 is ExtrudeAlongCrv can create an extrusion object but Sweep1 cannot. The algorithm used by ExtrudeAlongCrv should be considerably simpler than the algorithm used by Sweep1.
Well, it’d be easy to offer users a normal and parallel function in Sweep 1 Rail.
