Sweep1 and Sweep2 do not sweep the entire length of the open (not closed) rail(s) unless there are sections at both ends of the rails, or there is only one section and it is at the one end of the rail(s). This can be useful in some situations and a problem in others. Perhaps someday options will be added for sweeps to extend the entire length of the rails. In the meantime here are work-arounds which result in sintle surfaces rather than two or more surfaces.
Section(s) only in the middle of the rail(s)
Sweep1 or Sweep2
Select the rail(s) on one side of the section(s)
Select the section(s)
Complete the sweep
DupEdge the edge of the sweep surface
Repeat steps above for the other side of the rails.
The duplicated edges are used as sections at the ends of the rail(s).
Section not at one end of the rail(s)
Sweep1 or Sweep2
Select the rail(s) on on the side without a section at the end
Complete the sweep
The duplicated edge can now be used as the section at the end of the rail(s)
Note that with Sweep2 if the section at one end is only at the end of one rail and not at the end of the other rail, the final sweep will end of one rail, not at the ends of both rails.
