Sweep1 in Grasshopper Doesn't Work as Expected
Hey there,
I have a problem with Sweep1 node in Grasshopper. I have two sections, one placed at the beginning of the rail and the other one at the end. But as you can see on screenshots, shape, that grasshopper gives is not quite precise to the rail curve input. How do I fix this issue?
Thank you in advance.
Please upload your Grasshopper file.
script.gh (17.8 KB)
Here you are
You’re using a plugin and the file contains no inputs.
Please right click the inputs and click ‘internalise data’
Script Internaliesed.gh (17.4 KB)
ah, sorry. Internalised
I think in this case a loft with 4 curves would work better.
The sections are not identical and the rail is curved, this can be an issue for the sweep command.
Script Internalised loft maybe.gh (14.7 KB)
Thank you so much for provided response. I see, Loft with loose option selected you provided might be a better option here with two different sections and give better and more wanted results. Might give a shot at this solution then. :slight_smile:
Thank you again so much
