Sweep a rectangle along a closed polyline
Hi everyone,
I know it is quite a simple problem but I cannot figure it out what I am doing wrong. I am trying to extrude a rectangle through a closed polyline using Sweep2 command, but it complains…
Has anyone an idea of what is wrong here?
The idea would be to create this:
Thanks in advance
Sweep_test.gh (12.5 KB)
You cannot put the section in the corner.
This here works:
Sweep_frame.gh (17.8 KB)
hi you can use “Sweep Segmented” from flexibility plugin.
It is strange that if you switch the item component to 2 then it does not work, although the section is placed in the middle of the segment and the curved seamed. Is there a logical reason for that?
Difficult to say why it fails.
A Fit Curve component helps in this case but I see it is not consistent.
I tried with a different rectangle and the sweep 1 fails depending on where the perp frame is placed
Sweep_frame_issue.gh (14.6 KB)
If you don’t mind I think we should change the topic title to ‘Sweep a rectangle along a closed polyline’
The reason it fails might be related to finding the closest point on the curve. The following example does this better I think…
Sweep_frame_cp_frame.gh (15.9 KB)
