Sweep 2 function
I’m trying to make a curved surface using the sweep2 tool as I do in Rhino, all tutorials I can find show that it works the same but when I use the command in grasshopper I get a strange result.
Could anyone tell me what I am doing wrong?
Or how to alternatively make this shape. In the image here I show the surface I desire created in rhino and the strange surfaces generated by the command in grasshopper.
Thanks!
sweep 2.gh (1.7 KB)
can you share rhino file
i think you did something wrong
sweep 2 grasshopper.3dm (155.3 KB)
Thanks for the reply!
Here is the grasshopper file!
you need to flip the direction of the curves ; than you use sweep 1 or 2
Thank you very much!!
I’ve often needed this function and now I finally know it.
:slight_smile:
