Maybe this is known.
In the image above I have a hatch and some lines with colors set by object, not by layer. When I export them, they all show up black.
When the colors are set by layer all seems to work fine.
Hi Bogdan - thanks, I’ll check this.
@Bogdan_Chipara - when you export to svg, you get the print dialog and you get to set whether to use print color or display color - you want display color, I think.
ah, yes! this was the thing.
thanks, I haven’t seen display color.
