If I use Export (selected) to export some geometry via .SVG, the “OK” button reads “Print”. I know it is supposed to be calling the same thing as Print, but IMO it is disconcerting when you think you are exporting geometry and expecting to save it somewhere that you see Print as the OK button. Same for .PDF export it seems.
Also - and I think this is actually a toolbar/window management thing - open toolbars can obscure the print window.
Lastly, I have to check this some more*, but it seemed to me that the scaling box automatically went back to scaled to fit with a new file when I previously set it 1:1 for a previous file in the same session. Or is this now new deliberate behavior?
*Edit - yes, it has happened a couple of times now.
