You wrote GH file is not connected to Rhino file.
When I change the GH file, I see the result in Rhino, but I don’t like the results.
How can I connect these files?
The Srf param in the image I posted, unless it is “internalized”, is supposed to being geometry from Rhino to GH. That happens by selecting geometry in Rhino and then right-clicking on Srf in GH. Very basic stuff.
P.S. Since you are using ‘Offset Curve’, it appears you are treating surfaces as curves?
I’m not an eagle , that’s why I’m looking for help.
I see results when I change the GH offset parameter. When I select multiple surfaces, some of them have an outside offset, others have an inside. Maybe it has something to do with normal, but I haven’t found anything about it.
Yes, I treat triangles as curves, if I only deal with 1 triangle and didn’t like the direction, I would change (-/+), but I want to change 30 triangles and I see that there is something wrong
I would like to understand GH 1/4 as much as you .
But even in your results you can see that the offset is either outside or inside. I would like the offset to always be inside
Thank you very very much.
It looks like it’s working, unfortunately not on my side .
There must be something wrong in my system.
At the beginning I don’t have any results, when I delete the offset and put exactly the same one, then I have some results. All the vectors are pointing up, but the offset is still in or out.
Thank you very much, I’ll have to sleep on it.
as I wrote earlier, it worked for me yesterday $&^&^#^#
