If I create a mesh from a surface and compare bounding box - they’re usually the same (or very similar). However I have a problem with a particular surface and mesh bounding box that don’t match at all.
The surface bounding box is:
-484.928, 306.161, -2.153 -461.052 369.464 -1.080
The mesh bounding box is
-484.750 318.537 -1.711 -464.764 330.983 -1.360
This is if I GetBoundingBox in code. If I draw the bounding box manually in Rhino it matches perfectly…the Surface bounding box co-ordinates seem to be the ones at fault after manually checking.
I am using the GetBoundingBox(true) option for both the mesh and the surface.
Usually this code that compares the mesh BB to surface BB works fine when match meshes and surfaces so I am confused as to what is happening here. Any idea?
