hi
i am beginer in rhino . i want to create solid from this surface and 3d print this.please help me.
rhino car.3dm (13.5 MB)
hi
A solid in Rhino is a group of surfaces joined together without holes. You need to close the holes and then make sure the surfaces are joined without any “naked edges”.
Do you want to learn to use Rhino? Or are you hoping someone will do the work for you?
thanks for your reply. i want both of these:smile:
No any one for help me ?
A good place to start learning Rhino is by reading the User’s Guide and doing at least some of the examples in it. http://docs.mcneel.com/rhino/5/usersguide/en-us/index.htm
More information is available in videos and in the Level 1 & 2 Training manuals. https://www.rhino3d.com/tutorials
Two ways to make your surfade into two different types of solids. One is to close all the holes. The other is to offset the surface so it has thickness and leave the openings for the windshield, etc.
By the way, where did you find the model?
thanks a lot david. i download this model from grabcad website free models.
this is very important for my job. please help me.
Hi Key-Van
your model needs a lot of work. you cant expect anybody to help you here more than trying to activate you getting into rhino like david did. if you have specific questions people are sure quick to help.
to get this into a solid many question would have to be answered first since this is obviously an incomplete work and not to be finished in 10 minutes. questions like why would you have to print it and whats your further procedure, how big will it be printed… i assume you are trying to make a toy since you most likely will not produce a real car out of a downloaded file? but what do i know
the current dimensions are in “real” size.
many surfaces have to be added and trimmed. so this is not a quick one command job if thats what you hoped for, a lot of precise work is waiting for you
if thats not what you wanted then you have to get yourself another car model
or another job
that shall not be meant to be insulting but there just is no better news to this.
thanks for your reply. i just need some sample or tutorial for fix this
model.but you just rip off instead real help. shame on you. I’m sorry for
your manner!!
as i said this was not meant to be an insult. david gave you all the information you need,
and i raised a few questions which are important to be answered for anybody to help you.
if you have further questions people would gladly help.
I edit this model on solidworks but finally a little gaps last in model. I convert this model to rhino for fix this gaps . and 3d print of this in dimension of 245-90-65 mm.
we have a size now which can give us an idea how thick that body could be which is actually your job and i am not sure i can help you there much and still many questions are open.
we still dont know what you actually want to do with it, is it part of another part and you will assemble them or will this body be standing on its own? are you a beginner in rhino? do you know how to create surfaces from curves?
this body is half done if at all, there are probably multiple hours of work waiting after you understood what exactly you want to do with it.
i just want to change in solid this surface with 5 mm thickness.
thats not possible like that. at least not how you might expect. boolean functions can help you sometimes to avoid the manual work. but your model is more complex which means you would have to manually create the solid. meaning you have to create curves after understanding how it shall look in which region to create surfaces to trim and join them together. thats what i mean that there is no good news for this.
if you dont know rhino well and this is a beginner project then even though you may know other software packages this still will take a lot of time and understanding. even if people help you this will be not a quick click job. so a lot of effort from your side has to be contributed for this to work.
thanks for your guides.
Keyvan_Hassanpoor -
Hey bud I Hope this finds you well !
So- how did this turn out for you?
Were you ever able to figure out getting this to a point where you could print it out ?
All the best from Texas -
Chuck.
Hi chuck
thanks for your kind reply.
this is my first work.
i want to solid this surface but i cant .
i want to 3d print of this.
VIVA TEXAS!
Lynda.com has a number of lessons to help with Rhino. At $35 a month it is a bargain!
Keyvan_Hassanpoor -
Hey bud ! Ok, I’ve looked at the file.
Let me start here:
ALL of that being said, let me touch on a couple of things you’ll need to be familiar with in order to proceed to success.
ONLY CLOSED POLYSURFACES will successfully save out (EXPORT) as successful STL files to 3D print. (IF you get a successful STL file, mesh density in RHINO translates DIRECTLY to smoothness of the printed result - ACCEPTABLE trade-off is file-size.)
A CLOSED polysurface is achievable in RHINO but requires YOU to be aware of the condition of the component - the POLYSURFACE - at every step of the process until at the VERY END you again check AFTER the FINAL operation and the result is - again - a PROPERLY CLOSED POLYSURFACE. RHINO will report the condition (open or closed) as you go along. THIS REPORT IS ACCURATE and CAN BE RELIED UPON. Open the PROPERTIES side-bar and pin it to the right-edge of your screen. LEAVE IT THERE.
You’ll see conversations on topics such as class-A surfaces, etc. MOST of those are simply “Smartest guy in the room (discussion)” competitions, and have little meaning to most mere portals simply trying to achieve an industrial-level successful model, so unless you’re interested, or it applies DIRECTLY to a specific employment need, bypass those as SOON as you encounter ANY conversation on that or any related subject until AFTER you’ve mastered the basics necessary to meet your immediate need.
Ok, I can help you, but real help will take more than the space available here. STILL, let’s start -
Remember the LAST item you received shipped to you in a carboard box ? Ok, forget the ITEM you received,and go DIRECTLY to the carboard box. NOW - pick up the packing tape, and close the box, TAPING UP every single opening of the BOX until you’ve achieved a completely closed volume. THAT is DIRECTLY analogous to a CLOSED POLYSURFACE CUBE in RHINO. It LOOKS like a “solid” cube but YOU fully realize its REALLY an EMPTY VOLUME bounded by SURFACES ! THAT is what you MUST ACHIEVE in RHINO to later 3D-Print your part.
Now- imagine EVERY SINGLE “shape” in your car model. NONE of them are closed POLYSURFACES. Not a problem. All YOU have to do is decide how YOU want to proceed. What I would do, is start with the simplest surfaces first, and use “offsetsrf”, then at the command line pick “flip-all” from the choices, and POINT THE ARROWS INWARD. Then based on the scale you want to print out to, decide how thick you want the plastic piece of that surface to be printed, and use THAT as the thickness (for example 1-5mm, etc) . REALIZE that RHINO will NOT give you PROPER edge-treatments, so YOU will have to go back and make corrections to the result, but at least the result gives you an EFFECTIVE PLACE TO START.
There are “things” you will do to the resulting surfaces, like deleting the NEW SURFACE and re-running the command and picking the options in the command line that will give you a closed result IF you like how the “TEST” Surface looked when you created it.
IF you like THAT result, HIDE it and move to another surface, and repeat the process. SELECT the “part” you just made and check over in the PROPERTIES sidebar Does RHINO report that its a CLOSED polysurface? Do YOU like the result ? IF you DON’T like the result, restore the seperate thin offset surface, and work with IT and the main one to CREATE A CLOSED VOLUME of THAT surface. Let me know, and I’ll tell uou what to do if this is where you stop because you are stuck. IF you know what to do, then proceed … When you get THAT surface the way YOU want it, hide THAT one and MOVE TO THE NEXT ONE. (Put it on a hidden layer if you want to hide it that way, but I just use hide, as its probably already on the layer I want it to be on while I’m working on it. Sometimes not, tho, so either way is fine. Hide the part when you see its successfully CLOSED, and move on to the NEXT surface.
Do ALL of the simple BODY surfaces this way, and then get back to me. The other parts will be done a little differently.
Ok, THIS WILL get you started. Other comments, while helpful, kinda fall into the “smartest” category I mentioned above, and should LARGELY be bypassed (ignored) as unhelpful, ESPECIALLY references to other people doing your work for you, or those bypassing the point entirely by telling you to go away and spend some money on THEIR tutorials, first.
Get started as I’ve described here, and get back to me when you have all the simpler outer surfaces done. I’ll tell you then, what to do NEXT to do YOUR OWN WORK as you CLEARLY wanted to do from the beginning !
Ok, Good luck, and
All the BEST from Texas -
Chuck.
Clarification - A closed surface in Rhino can not have any duplicate surfaces or interior surfaces connected to the outer surface… So using the box analogy you would also need to remove the flaps which you fold under the outer surface.
