Hello Guys,
I’m having a hard time on this.
I usually use Surface Morph to “develop” a module on a 3D surface and it simply works fine.
In this case I need to adjust mesh in order to be 3-axis machined (and so with no undercuts, in this case all the vertical surfaces are straight extruded), so I’ve tried with this method: curves on the bottom from the previous Surface Morph, projected curves on the offsetted surface… and then connect them with a Loft.
Unfortunately the Surface Split on the offsetted surface doesn’t work (and it happens all the time, with different modules and different surfaces). I’ve also tried to split the surface with an extrusion from the bottom or pull and project the curves… nothing…
Can you help me?
In addition: is there a smartest method instead adding all this stuff?
Thank you All
test.gh (44.6 KB)
