Surface relief plugin
I want create relief from this image. use surface relief plugin.this plugin create better relief then i can purchase surface relief plugin.
You’ll probably need to interpret the depth in that image in a smart way. It might be worth trying to create a depth map from that image using AI tools first and then use the result for a height map.
Surfacerelief plugin create depthmap?
You could try a surface relief plugin like this one. I don’t have any personal experience with it though
https://www.food4rhino.com/en/app/surfacerelief
