Maybe i’m getting wrong the purpose of the command, but it seems that it should detect if a curve is isoparametric of a surface. Well, if so, it apparently doesn’t work. Even when checking previously extracted isocurves. Prove on the video.
what I’m missing? thanks
In my understanding this method checks if a curve is “equal” to some isoCurve of the surface. Is this correct?
Hi @aitorleceta,
This from the API help:
Determines if a 2d curve is isoparametric in the parameter space of this surface.
The “2d curve” is critical, as this refers to a parameter-space curve. Your curve is just some planar 3d curve.
To create a 2d curve from a 3d curve, use Surface.Pullback.
– Dale
oh, I was blind! thanks @dale!
