Surface grid help?
any idea how to create a grid on this surface using points??
made some lines in the left viewport to show what i am trying to achieve
any help would be appreciated !
If its not clear please also let me know =)
Thanks!
Intersecpt points.gh (21.7 KB)
Glass Geometry.3dm (237.8 KB)
Image1|690x345
Not sure if this is 100% what you are looking for. But it might be a good start. I’ve attached the GH file of what I did with internalized data. I used your curves but rebuilt them. May or may not be an option depending on what these curves are for.
I did this in Rhino 6 but I think it should still load fine in 5.
Surface-Split.gh (14.4 KB)
Hi @aroncal02
here is a different method. I don’t believe either of these is going to get you exactly what you’re looking for. But hopefully it will give you some different approach ideas.
Intersect_2.gh (29.1 KB)
Thank Ra! Ill check them out now :pray:
