Surface Curvature Analysis
Hi All, @dale ,
There is a neat method in good old RhinoScript called SurfaceCurvatureAnalysis which returns all the min/max curvature values of the entire surface.
Maybe I’m overlooking the obvious, but I’m missing this method in RhinoCommon. I want to avoid sampling the entire surface… so it would be very nice if this method could be exposed to RhinoCommon.
Thanks, Jess
Hi @Jess,
No, you’re not overlooking anything.
https://mcneel.myjetbrains.com/youtrack/issue/RH-66237
– Dale
CurvatureAnalysisSettings Class contains CalculateCurvatureAutoRange but is missing a CalculateCurvatureMaxRange.
RH-66237 is fixed in Rhino WIP
