SubD treatment with RhinoScripts?
hi @Dale,
Is there any strategy of how SubD objects will be handled with existing RhinoScript methods?
I see some analogy with when Extrusions were introduced and it took 5-6 Rhino 5 service releases to iron out problems and eventually they ended up being treated as Breps and working with all brep methods, unless specifically needed by object type. So I was wondering what the plan for SubDs is - just quickly testing a few scripts and they seem to be pickable as Polysurface but then they fail on further operations (which I did not investigate in detail).
thanks,
–jarek
They seem to have the same behaviors of meshes (and in fact have an underlying mesh). You could just use a mesh or extract the subD mesh, do stuff, and output back as subD.
https://developer.rhino3d.com/wip/api/RhinoCommon/html/M_Rhino_Geometry_SubD_CreateFromMesh_1.htm
hi Michael, thanks, good to know.
My questions is specifically for existing RhinoScript (VBscript) methods set. It was prompted by the script I was trying that specifically allows only Surfaces and Polysurfaces to be selected and it allowed SubD objects (but not Mesh objects), but failed later on. That’s why I am trying to figure out what the strategy is and possibly plan in advance for my published plugins and our in-house toolset to cooperate.
–jarek
