in Vbscript
how to use GetObject to select the surface from polysurface, or other sub-object
I’m afraid you can’t with VBScript, none of the subobject selection methods are exposed yet. The only way I know of to get to a sub-surface with scripting is with Python and RhinoCommon. Otherwise, the common workaround is to explode a copy of the polysurface in question, isolate the surface(s) you need, and throw away the rest…
–Mitch
Below is an example with Python… --Mitch
import Rhino, scriptcontext
#Example adapted from Python forum post, thanks to Vittorio and Emilio
def DuplicateBRepSrfs():
prompt="Select BRep surface(s) to duplicate"
srf_type=Rhino.DocObjects.ObjectType.Surface
rc, subsurf_refs = Rhino.Input.RhinoGet.GetMultipleObjects(prompt, True, srf_type)
if rc != Rhino.Commands.Result.Success: return
if subsurf_refs:
breps=[]
#breps will contain the duplicate surface *geometry*
for srf in subsurf_refs:
face=srf.Face()
brep=face.DuplicateFace(False)
breps.append(brep)
#if you actually want to add the objects to the document:
dupsrf_IDs=[scriptcontext.doc.Objects.AddBrep(brep) for brep in breps]
scriptcontext.doc.Views.Redraw()
DuplicateBRepSrfs()
Thanks for help
It is also worth noting that the GetObject function in rhinoscriptsyntax does support subobject selection (note the subobjects optional parameter in the function)
https://github.com/mcneel/rhinopython/blob/master/scripts/rhinoscript/selection.py#L170
