SubD Selecting surfaces defined by corners
Is it possible to select all faces defined by 4 corners and Double-click somewhere in the middle ?
not in one go, you can shift+ctrl+double click between those selections to fill in the row between them. (works for edges and verts too)
but then you select the center with the select to boundary tool-
for those who work with commandline input.
the command in above video is:
_SelFacesToBoundary
Thanks!
May I suggest, In one go would be even better!
Select the corners and DoubleClick any Surface inside.
