Hello.
I found a bug-like issue with SubD and I would like to share it with you.
We are making a topographic model for 3D printing.
When we scale a large SubD to a smaller size, say 1/10000, the display goes wrong.
The behavior seems like a graphics problem.
Changing unit-related settings did not fix the problem.
At any rate, copy-pasting the SubD with the strange display into a new file fixed the problem.
Remember to raise the file unit tolerance or use the right units for the file. What size is that object when scaled down, and is it far from origin?
We often make a block of the object close to origin and then move the block when having to work far from origin.
