Hi
Some issue with the bridge here, don’t know why it wouldn’t work…?
Would love to get some suggestions how to resolve this.
To bridge these subD parts.3dm (3.1 MB)
thanks a lot
Akash
Hi
thanks a lot
Akash
your edges have to have the same #- also follow command prompts carefully-
Thanks Kyle
Yes I know the edges need to be the same numbers.
I’ve edited the parts to the point of both having 18 edges each
[unless I’m counting wrong over and over again…] and followed the command several times before posting here.
Still am I missing something…?
Akash
I’m good at it!
Hi
I’m on the Mac Version 7 WIP (7.0.20105.12066, 2020-04-14)
thanks
Akash
is it perhaps possible that existing reflect has to be removed first
[I have it on the Y in both parts…?
thanks
I didn’t delete the reflect, I didn’t rule your model. I only built a bridge.
Okey thanks
Still something here is preventing it.
[I do know how to run the bridge command used it before on other things]
Akash
worked great here, try preselecting both edges and then run bridge-
Thanks a lot
the preselecting solved it.
Akash
