Hello, is there a way so that I can extract horizontal and vertical curves out of SubD seperately!!!
Sub-D.3dm (129.5 KB)
You should be able to use the DupEdge command and then select the parts you need.
is there any way in grasshopper? The solution you told will take a lot of time and that too everytime!
